Dana 60 HELP!!!!
Old 04-10-2010, 06:12 AM
bigiron2
Default Dana 60 HELP!!!!
Hello,
I recently purchased a 68 roadrunner pro street set-up with coil over rear, ladder bar suspension. narrowed dana 60 spooled with 4:30 gears. It goes very well under power then when I left of the throttle you hear a chatter/marble sound coming from the rearend. I have had the rearend apart 3 times with very good dana people and they are all puzzled. The gears, bearings, lash, wear all look excellent. I have even changed both pinion bearings and made no difference. I am looking and all items to check. It just does not seem it's the rearend but very puzzled. Thanks!!!
bigiron2 is offline
Old 04-23-2010, 12:29 PM
Scooterz
Have you got this figured out yet? As much as this sounds goofy, take a look at the exhaust... your drive line... you get on it, it's fine. You let off, your geometry has changed... what could be coming in contact w/ the drive line or exhaust as the suspension is changing from loaded to relaxed?
Scooterz is offline
Old 04-28-2010, 07:06 AM
oldandtired
oldandtired's Avatar
U - joint noise echoing thru the driveshaft?
Dave
oldandtired is offline
Old 04-28-2010, 08:23 AM
...loose muffler internals.......
