which headers and heads sbc combo
Old 03-03-2010, 08:44 AM
et7333
Default which headers and heads sbc combo
I don't know enough about flow# but I know using a flat tappet has its limitations, so using only a flat tappet what heads,headers, and modifications would you use with the current combo for an improvement:
383 sbc,hooker super comp 1 3/4 #2131 headers,comp .558 550,260,266 at .050,108 on 104 icl,13.6-1,dart iron eagle 215 platinums,2.05 1.6 valves bowl blended and port matched to a 2925 super victory,alky 810 carb,power glide,4.56 gears,4800 convertor,3100 lb car.This is a 1/4 drag car.
et7333 is offline
Old 03-03-2010, 11:05 AM
bigmack
have you ran the car with that setup yet if so what kind of numbers 60' 1/8 mile 1/4, mph.
bigmack is offline
Old 03-03-2010, 11:25 AM
et7333
10.32 at 130 mph
et7333 is offline
Old 03-03-2010, 04:10 PM
I972Nova
Sounds like it runs pretty good for what it is.
I972Nova is offline
Old 03-03-2010, 04:31 PM
et7333
I really can't complain just seeing if theres more without spending a bunch of money
et7333 is offline
Old 03-03-2010, 07:44 PM
bigmack
man the only thing i would try is a solid roller cam. but your car runs great just the way it is.
bigmack is offline
Old 03-03-2010, 10:03 PM
Those are some good numbers no doubt. 10.30's aint nothing to sneeze at.
BUT:
Comp Cams makes a 630/630 solid roller, with this cam I wouldn't be afraid to say that you'd be well into the 9's.
Cp
Old 03-04-2010, 08:08 PM
BUT:
Cp
I don't know Charles, i spent a $1,000.00 to go to a solid roller and only gained 1/10, going from a .595 flat to a .624 roller on gas. He's got a good combo i'd stick with it. Not many cars can run 10.30's with a 383 @ 3100 lbs.
Old 03-04-2010, 08:17 PM
Well dont tell me John, tell him - He's the one not content running 10.30's not me>?
But as far as your cam change? It just goes to show, some tenths cost more than others and that you never know what works till you try it, right?
I'm sure it wasnt the first time you made a change and didnt gain much, I know it's happened to us all at one point or another.
Cp
Old 03-04-2010, 10:07 PM
Cp
Charlie you wouldn't believe the mistakes i've made changing this and that, Bullit actually made the recomendation, and i know the people at Bullit. Both cams were Bullit, but i guess the engine combo was more suited for the flat tappet cam. It was a junk 406" with track 1 heads, and it wound up breaking a rod bolt which killed the motor.
