In need of a 302 race block
Old 02-09-2010, 08:40 AM
a63fairlane
Default In need of a 302 race block
I am in the process of building a fox body mustang to start racing. I have a couple of stock blocks but i am not sure about putting the scat 347 kit i have into a stock block. I also do not want to put the machine time and money into the stock block for it to be worn out in a few months. If any one has any suggestions as to where i can find a good block for an honest price please let me know. I am also interested in any kind of 351 Cleveland parts or info thanks.
oh am i the only ford guy on here?Hope not.
a63fairlane is offline
Old 02-09-2010, 10:15 AM
Not a Ford person, but the Dart SHP block will go to 800 HP, available in 302 or 351 versions.Below is an ebay listing, not cheap, but free shipping. Carl/Hink may be able too do you better.
http://cgi.ebay.com/ebaymotors/Ford-...item5638c540e9
Old 02-09-2010, 09:06 PM
A stock 302 block can be a option with a main stud girdle upgrade.
If you dont, it will split right down the middle if you start making any decent HP. 350/400 is pusing it in stock trim.
My suggestion to you would be to find a seasoned 351W block, they are much stronger than the little brother 302, plus your starting out with 351 cubic inches, put a stroker crank in it and you'll have you a nice 400, then my friend, you'll be cooking with crisco.
I'd skip on the cleavland thought, getting hard to find them babies, plus finding good heads? forgetaaboutit.
Cp
Old 02-10-2010, 05:01 AM
hink
You might look into the Dart SHP block and build a 363 cid engine using one of their blocks as you can buy thier 302 block with a 4.125 bore.
If you need a block and rotator let me know as we are a dealer for Dart and Callies crank Co.
Here is a link to look over
http://www.dartheadstv.com/featured_...php?reset=true
Good luck which ever way you go
hink is offline
Old 02-10-2010, 05:40 PM
gearhead1011
gearhead1011's Avatar
I would agree with cepx111 and I am a Ford guy. Start with a 351w and you can get a lot out of a stock block. I had built a stock windsor block with a stock crank and cleveland heads that was making around 600 hp. I will admit that was on the edge of what those parts were capable of but it held up fine.
gearhead1011 is offline
Old 02-13-2010, 06:56 AM
a63fairlane
Thanks for all the help everybody and the dart block sounds good now i just got to figure out how to spend that much with out the my better half findin out
