INTAKE MANIFOLD
Old 01-23-2010, 04:18 AM
JEFF69Z28
Default INTAKE MANIFOLD
DOES ANY MANUFACTURE HAVE AN ADVANTAGE OVER ANOTHER,I HAVE A SUPER VICTOR PORT MATCHED ON MY SBC,WILL DART OR ANY OTHER MAKE MORE HP?
JEFF69Z28 is offline
Old 01-23-2010, 05:19 AM
JimmySmith
Default manifolds
Give us some specifics on engine ,car ,shift rpm and mabe someone can help. Also intended use Later J.Smith 4621 racing
JimmySmith is offline
Old 01-23-2010, 05:22 AM
need more info ..
but can say the super victor did not impress me on any sb I ran it on.
Old 01-23-2010, 08:25 AM
JEFF69Z28
Default Re: manifolds
406,SOLID ROLLER CAM,850 HOLLEY,8 INCH CONVERTER,4.56 GEAR,86 SS MONTE CARLO,SHIFT AT 7100 RPM,GO THRU TRAP AT 7100 RPM 128 MPH.
Old 01-24-2010, 05:59 AM
JimmySmith
Default intake manifold
My car 3200 lbs 360 mtr 220 heads, PG 5800 conv. , 5.38 gear, 31 tire runs .03-.04 quicker in 1/8 with a Holley 300-2 over a Vic Jr. never did compare on 1/4 my cam is [email protected] shift @6800 . Later J.Smith 4621 racing
Old 01-25-2010, 06:16 AM
On my 383 and 434 the super victor was very slowed compared to everything else (including a ported Dart Wilson and a cheap Pro Products)
Old 01-25-2010, 06:23 AM
andybyrd
My 2 Cents -- I ran a super victor on my SBC 434 and A Dart with a Holley H/P 950 6.10 in the 1/8 super victor 6.09 yesterday with the Dart but the Dart is straight out of the box the Super victor was ported and had a lot of pollish work done on it. I think If money is no object buy both work both test them both then sell the one you don't want Here on RJ, If money is tight then I would buy the Super victor it is probably the best intake out there for it's price, thats just the way I see it hope it helps. be safe
Andy
andybyrd is offline
Old 01-25-2010, 10:20 AM
curtisreed
curtisreed's Avatar
Default Re: intake manifold
Is this a stick shift car?
curtisreed is offline
Old 01-27-2010, 11:03 AM
jmarksdragster
jmarksdragster's Avatar
You didn't say what heads, that will make a difference. On anything roughly 200cc and smaller any of the larger intakes will be OK unless the heads are significantly worked over. For larger heads or well ported heads any intake can benefit from some work.
jmarksdragster is offline
Old 01-28-2010, 04:52 AM
JEFF69Z28
AFR 210 FULLY CNC
