how tight for roller cam button bbc
i have a hubert solid roller cam just needing to know how tight to make the button on the cam or do i get it tight and back off or is it torqued
? thanks guys
? thanks guys
Tod74,you do this by wiping a little grease in the inside of the the timing cover and the timing button,you than stick a little ball of modeling clay on the button,torque down the cover,remove the cover ,than check the thickness of the clay with your micrometer and keep shaving the button until you are where you want to be,thats how I do mine anyway.
