bbc casting number on block, please help me
Old 12-26-2009, 07:05 AM
robertstell
Default bbc casting number on block, please help me
I have what i beleive is a 427 tall block with the casting number 861959, and a little ways toward the top of the block are the letters GM 10 T . Can anyone confirm this being a talldeck block...thanks alot, Rob...
robertstell is offline
Old 12-26-2009, 07:37 AM
DirkaDirka
DirkaDirka's Avatar
Are you sure that the casting number is not 361959 instead of 861959??
I found that the 361959 is a 454 block that was used in the 73-75 Chevelle--73-76 Passanger car I believe--and the 75-85 Truck LD.
DirkaDirka is offline
Old 12-26-2009, 07:39 AM
fla1976
fla1976's Avatar
Are you sure it isn't 361959? If it is, it is a 454 between 73-90.
http://www.mortec.com/bbc.htm
Beat me again Dirka!!
fla1976 is offline
Old 12-26-2009, 08:04 AM
robertstell
Default block casting number corrected, 361959
The first number was a 3 instead of an 8, can you tell me if it is a tall deck? Thanks alot, Rob. Toward the center of the block is alo has GM 10 T. I need to order a distributor for it and want to make sure I get the correct length.
Old 12-26-2009, 08:50 AM
cam67152
its a 454 from 1973-90 could be a 2-bolt or 4-bolt, all 454's are 9.8" deck height, (except bowties).
cam6752
cam67152 is offline
oldandtired
oldandtired's Avatar
Buy a distributor with a slip collar and you won't have to worry about it.
Dave
oldandtired is offline
Old 12-26-2009, 08:55 AM
cam67152
I believe T stands for the Tonawanda assembly factory, not Truck.
cam67152
cam67152 is offline
Old 12-26-2009, 10:11 AM
Quick and easy check, look at the front of the block where the water pump mounts, if the top of the water pump mounting surface is within 3/16" from the deck it's a short deck 9.8. If the mounting flange is about 7/16" to the deck it's a 10.2
No matter what the casting #'s are.
Old 12-26-2009, 11:59 AM
itsabird
x2
itsabird is offline
