question about nos solenoids
Old 12-23-2009, 09:30 AM
bowhay
Default question about nos solenoids
i have a cheater plate but i need to get new noids
do i have to run the cheater noids or can u use say powershot or super powershot noids
i know the orifice is defferent and ive heard it will change the size of the shot
is this true....im new to the hole nitrous thing and any advice would be appreciated
bowhay is offline
Old 12-23-2009, 01:47 PM
bbchevy
Default Plate
You can run ANY Noid you want!The Noid has a Limit of what it will Flow,as the Plate?
Later
G 8)
bbchevy is offline
Old 01-11-2010, 01:49 PM
chevyfireball
I had a 400 powershot plate system on my Camaro. It came with Cheater solenoids for the fuel.
chevyfireball is offline
Old 02-01-2010, 12:57 PM
rick329c
Default NOS
You can run any solinoid you want but the bigger the orfice on the solinoid the more it will change your tune up so be careful.
I had a Top Sportsman Car that I used to brag I only shot with 200HP jets, however i had the big NOS brand bottom exit Nitrous solinoid on it and it does make a big difference.
rick329c is offline
Old 05-06-2010, 07:36 PM
blaktrukpilot
Default nitrous solenoids
How often do you need to rebuild them?
blaktrukpilot is offline
Old 05-06-2010, 10:15 PM
Default Re: question about nos solenoids
My advice is to use the parts that NOS put together as a kit and follow their instructions for the tune up. Someone who is familiar with Nitrous mixing matching things is different than a beginner swapping stuff around. Just my opinion.
