CAM WALK
CAM WALK
HAS ANYONE USED A CLOYES 2 PIECE QUICK BUTTON TIMING COVER.BY THEIR ADD YOU SHOULD BE ABLE TO ADJUST CAM END PLAY WITHOUT REMOVING THE COVER,GOOD OR BAD IDEA?
AND YES MY CAM IS WALKING,IT IS SET AT 38* AT IDLE BUT WHEN I REV THE MOTOR IT RETARDS ABOUT 2-3*
I have used one on a sbc for 2 years with no problems.When I first put it on the inside of the cover was hitting the front main cap before the cover sealed on the gasket.I removed some metal from the cover to get clearance.Bill Bates.
we have a timing lite mounted on a stand,that runs during dyno pulls.i have found it is comon to gain or lose timing at the top end of the pulls. not realy sure why? last hei with advance lock out would retard 2 to 3 in the last 500rpm of the pull. slack in the timing chain, distributor shaft end play, gear wear, cam walk. all might contribute some, and lets not forget the control module. i like solid cam thrust buttons. roller bearing types have seized up, and the needle bearings have gotten through moroso oil pick tubes :cry: had good luck with cloyes covers, some times they dont get along with stock type water pumps. hope this helps stickboy331
Re: CAM WALK
Re: CAM WALK
It's hard for me to think that cam walk can cause 2 to 3 degrees of change in the timing. What David was talking about (crank trigger) takes away all the movment of the cam and gives you the true timing. The cam twist and flexes due to driving the oil pump, it's takes 25 HP and more to drive an oil pump at high RPMS, especially if you're running heavy weight oil and pushing 60 to 100 LBS of oil pressure and that's where most of your timing change is comming from. That's why a crank trigger gets it right. Think about it the cam is about .800 dia. slightly more than 3/4" dia and 2 ft. long. That's why most of the big dogs run dry sumps and crank triggers and all NASCAR teams do.
I'm not saying your cam is not moving, but i am saying that a button will not correct the timing problem completely.
Thanks for the info Zip i just talked to MSD and he said to install a crank trigger and the problem should go away if it doesnt than more than likely the cam is walking.How much timing change would you exspect if my cam was walking.
