help with mustang slicks
If your going to run a slick on that wide of a wheel I assume you dont have the Quad shock setup, at which point you should be able to fit a 10" or larger tire tire, may be close but, as long as you clear the caliper get the wheel on there and see how it looks with no tire on the wheel and measure for clearance.
