Ford 8" Question
Old 11-03-2009, 03:22 PM
jreiley
Default Ford 8" Question
I am aware that a 8" is not in the same league with a 9". I have a 29 Ford hot rod with an 8". The current engine puts out 300hp at the read end and I've not had a problem. Is there anything I can do to this rear end to beefen it up to hold more hp?
jreiley is offline
Old 11-03-2009, 04:09 PM
TS1955
If this is a vehicle that is going to be street driven and not have slicks bolted on, I'd leave it alone. JMO!
TS1955
TS1955 is offline
Old 11-03-2009, 04:18 PM
fla1976
fla1976's Avatar
Default 8"
X2. Unless you plan to race it, I'd be content with the 8 inch.
fla1976 is offline
Old 11-03-2009, 05:38 PM
8"er's are actually pretty strong as it is the same design as the 9" with the pinion down low on the ring, hence more gear contact/strength. There are quite a few ratios available as well as limited slip units.
