2.3L 4 cyl
Old 10-14-2009, 12:38 AM
team37racing
Default 2.3L 4 cyl
Ok I know it is small but hey looking for some tips on build. Mainly in the head. Looking to build motor for a 3/8 mile 17 Degree banking track.
A lot of the guys that I talk to are using solid lifter, and basically a complete roller. Does any one know about what the max hp you can get out of one of these?
I am trying to find tricks or tips to try and be one step ahead of the next guy behind me. The other problem is, that a lot of them all use the same engine builder around here, so I don't think everyone is always getting what they pay for. Any suggestions are greatly appreciated. Thanks.
team37racing is offline
Old 10-14-2009, 12:08 PM
signsbyesa
i posted this under engines:
in this months carcraft kenny duttweiler builds a 299sbc for a
400mph salt/flats pusher, they call it the baby rat:
a 8.5 inch deck dart block, crower steel 2.8 stroke crank,
crower rods w/9.5:1 diamond pistons, 4.125 bore, dart little chief heads 235cc rec ports, 2.30/1.55 valves, short duratkions duttweiler cam
w/0.850 lift, mild 1.62:1 rockers, EFI, turbocharged, and a hogan's sheet
intake. 1,450hp w/another 600hp with an additional 10psi, wow
they thinki it will do 430mph :shock:
signsbyesa is offline
Old 10-14-2009, 12:38 PM
oldandtired
oldandtired's Avatar
"Small" engines can be deceitful. In 1972 Smoky Yunick built a 208 cubic inch small block Chevy for Indy. It was 3.875 bore x 2.200 sroke with a 6.250 rod. From 6,800 to 9,800 rpm, made over 1,000 HP on alcohol.
Now that's buzzing... Dave
oldandtired is offline
Old 10-14-2009, 08:24 PM
Wow thast pretty neat, BUT guys, but I see no comparrison from the 2 SBC's ya'll mentioned and this guys question on his 2.3 INLINE 4 banger?
Cmon guys help out, or......
Old 10-14-2009, 08:58 PM
DirkaDirka
DirkaDirka's Avatar
Ok. First things first. Where is here?? What is the nam eof the shop that builds them. Me personaly have a 2001 celica with a 1.8l. I am going to be building it also aalong with my 93 Stang. Tell us some more info on teh motor will be nice as in OHC and what not.
DirkaDirka is offline
Old 10-14-2009, 10:06 PM
I believe the engine this guy is refering to Dennis is the 2.3 ford used in mustangs and pintos and yes it is a OHC motor.
I know stock they are slugs but they can make decent power with the right parts.
Offenhauser makes a nice aluminum intake that you can slap a holley 4 barrel carb on it.
Old 10-14-2009, 10:22 PM
DirkaDirka
DirkaDirka's Avatar
Ok I am gonna have ot see if I can work some magic at work later on. And find this guy some parts.
Old 10-14-2009, 11:28 PM
Ok this site has just about anything you need to hop up a 2.3 ford
www.esslingeracing.com
Old 10-15-2009, 03:44 AM
signsbyesa
cepx, just showing him what can be done, if this can be done to
these motors, his 4 hole can reach extreme power, i have only
rebuilt a line 6 and added a bigger cam and it was awsome going
up hills :wink:
for a start, competition cams will grind cam for what you want,
and you know a bigger cam is a GOOD START 8)
Old 10-15-2009, 06:43 AM
cbtlr
Look up Racer Walsh on the net.Lots of performance parts for the 2.3L pinto engine..
cbtlr is offline
