Supercharger REPAIR?
Old 08-20-2009, 06:09 AM
bbchevy
Default Supercharger REPAIR?
Do Any of you Guys know of a Repair Service Here in Michigan,that can handle servicing a Weiand (GAS) Supercharger?
It will NEED someone that can do MORE than a strip Job?It has some Issues in the Gear and Rotor Department?
Seems that it was apart before and Patched up?It had a Weird NOISE when Running(Gear Grinding)?
It DOES NOT Spin Smooth?
I have a # of a Fellow in the Indy Area that use to Work for,Prudome?But,i have yet to Reach Him?
Let me know if you know of Someone?
THANKS
Greg 8)
[email protected]
bbchevy is offline
Old 08-20-2009, 11:55 AM
kwkracing
Some one probably took it apart and did not shim it properly, so the rotors clashed a lil, then galled the aluminum abit making it hard to turn and sound like that. I dont know anyone in your area... sorry
kwkracing is offline
Old 08-20-2009, 02:12 PM
OneBadGMC
Nobody that I know of in Michigan...
You might try http://www.dyersblowers.com/
They're up in Chicago.
Could also try Oddy's in New York.
http://www.oddysracingengines.com/oddy_contact_us.html
Otherwise, probably the best place to send it would be RBS Superchrgers in Cali.
http://rbssuperchargers.com/
If it's run improperly, assuming the rotors didn't touch the case, the rotors are more than likely junk. Have any photos?
OneBadGMC is offline
Old 08-20-2009, 03:23 PM
kwkracing
Haha, send me you junk parts!
Old 08-20-2009, 03:32 PM
bbchevy
Default >?
Thanks for the responces!
I Know all about RBS.Dyers,ODDy and so on?Its a STREET Deal unstripped.I found a fellow in Kankakee,Il.
I'll run it down there and see what can be done with it?
NO PICTURES?
The Previous Owner Deffinately should have Kept his Day Job?
He worked at the Corner Grosery Store,in the MEAT DEPARTMENT.......!
Later
G 8)
bbchevy is offline
Old 09-02-2009, 03:59 PM
quick8dragster07
I'm a few days late.. but I always send my stuff to Darren, DMPE I think he does the best work out of any supercharger shop.. And he IS in Michigan as well, to boot!
quick8dragster07 is offline
Old 09-02-2009, 04:18 PM
bbchevy
Default Blowers
Just Finished bolting it on this Afternoon,and its PACKING AIR!
THANKS
for the Help!
Later
G 8)
bbchevy is offline
Old 09-02-2009, 10:06 PM
kwkracing
Well what was ur diagnosis?
Old 09-03-2009, 05:53 AM
bbchevy
Default Blowers
Seems that it was APART before which i knew by Looking at the MESS!
The Gears on the Frt.Rotors had been,Beat on as He said and Realy BOGGERED up the Splines on the Rotors.The Gears were Actually Junk,along with being out of Time,New Bearings,ETC...!
Also had a bunch of Stripped Holes in the Case that were Repaired.So,its all GOOD Now!
Later
G 8)
bbchevy is offline
Old 09-15-2009, 11:50 AM
KarsonRacing
Default repair
I know you already found someone, but for future reference, Don Gerardot outside of Ft Wayne Indiana does blower repair. Might be a little closer for some guys. http://www.gerardot.com/
KarsonRacing is offline
