carb prob ??
Old 08-12-2009, 07:51 PM
gpracer
Default carb prob ??
i have a chevy 413 and has a 750 hp holley carb and the problem we are having is it will drop rpms after the temp gets to 180 degrees in gear only but runs perfect till we get up to 180 any advice on this thanks or if u need more info will let u know
gpracer is offline
Old 08-12-2009, 11:09 PM
Could you be alittle more specific about your problem.
What do you mean by 'drop rpms'?
Old 08-12-2009, 11:49 PM
gpracer
when in gear and u push throttle going up against converter and let off of throttle drops rpms down to around 400 only does it when temp gets to 180 other than at that temp it dont drop rpms thanks for any help u can give
gpracer is offline
Old 08-13-2009, 04:39 AM
oldandtired
oldandtired's Avatar
I believe you are tuned to the wrong temperature. I've had many an engine that runs great when cool but the real world starts at 160 and up.
JMO Dave
oldandtired is offline
Old 08-18-2009, 02:03 PM
wingjohn
Default droppin idle speed
don't know if you have a spacer under the carb to isolate from the heat..might help. I have seen the fuel in the carb heat up and expand and dribble from the boosters and drop fuel into the engine..essentially causing a flooding situation. Look into the carb when the idle is dropping. Watcha see?
wingjohn is offline
