Dome Pistons - Why
Old 08-11-2009, 04:00 AM
jreiley
Default Dome Pistons - Why
Is there any advantage to using dome style pistons?
jreiley is offline
Old 08-11-2009, 04:08 AM
chevyfireball
More compression?
chevyfireball is offline
Old 08-11-2009, 05:25 AM
More compression ... in the past we've cut the heads a long ways and keep a flatter piston to get better flame travel
Old 08-11-2009, 06:05 AM
oldandtired
oldandtired's Avatar
I love the BIg Chief stuff!!
Dave
oldandtired is offline
Old 08-11-2009, 06:43 AM
ARUSSELL
in the high end markets, Pro Stock and Nascar Cup, the cylinder head chambers are getting smaller with shallower valve angles. This alows either a flat top piston or a dished piston to keep the compression up and still get good quench and flame travel.
ARUSSELL is offline
Old 08-11-2009, 07:28 AM
signsbyesa
yep, acomplish the high compression with a flat piston and make
the chamber small, but for those with large chambers can use the
dome to fill the chamber, but flats are a better plan to get high
compression, good luck :wink:
signsbyesa is offline
Old 08-13-2009, 09:45 PM
Default Re: Dome Pistons - Why
They look cool as hell.
Old 08-13-2009, 10:12 PM
HaHa, LMAO, i've never seen a dome piston in a running motor.
Old 08-14-2009, 04:11 AM
curtisreed
curtisreed's Avatar
I've seen a few in previously running motors moments later. ops: ops:
curtisreed is offline
