torgue converter broke
well i was doing my burn out and the converter let go. i pull the trans out and drop the pan didn't have any big pieces of metal but real fine metal shavings, do i need to get rid of the cooler or how do i clean the cooler and lines. thanks for your help.
brake parts cleaner and compressed air. flush it both ways until comes out clean. If has ALOT of metal or feels restricted at all when blowing through it, change it out. Best to have trans gone through and everything cleaned out. It doesn't take much to stick a valve and burn trans up. I broke a set of pump gears and had a small piece stick a valve and burnt up reverse clutches because slipping backing up when trans brake applied
hey thanks guys oh yea it was a redneck converter only my 7 passes on converter on my 8th it let go i email redneck and told them what happen and all they could tell me was to send it back, and paid 150+parts and freight and they will fix it. i don't thing so i'll get a good one this time and someone that will stand behind there converter. thanks again.
