VALVE ADJUSTMENT 4/7 SWAP CAM
Old 05-11-2009, 11:46 PM
jrthone
Default VALVE ADJUSTMENT 4/7 SWAP CAM
Wats the easiest meathod to adjust my valves on a BBC with a 4/7 swap cam?
jrthone is offline
Old 05-12-2009, 01:04 AM
The exact same way you adjust them on any engine. the 4 7 swap has nothing to do with it...unless you use a method like "Bring number 1 to TDC then adjust intakes on these cylinders.... etc
Just adjust each valve when the lifter is on the base circle.
When the ex starts to open, adjust the intake. When the intake has opened completely and is on it's way closed, adjust the exhaust.
Old 05-12-2009, 11:55 PM
jrthone
That answer hasnt realy given me a method. I have always done it starting on TDC etc. Wats the best way to do it. and the quickest
jrthone is offline
Old 05-13-2009, 01:10 AM
Old 05-13-2009, 03:16 AM
CamBirdRacing
Do it the way Tod said to do it.
CamBirdRacing is offline
Old 05-13-2009, 03:26 AM
TS1955
I adjust mine like Tod said only I adjust them in the firing order. I do the exhaust first, then the intakes. This way I'm only rotating the engine over a couple of times.
TS1955
TS1955 is offline
Old 05-13-2009, 04:27 AM
suicidebomb
Just lash them the way you've always done it. WITH the new firing order, you'll be just fine. As long as the lifter is on the base circle, for the valve you are adjusting, everthing will be just fine.
suicidebomb is offline
Old 05-13-2009, 02:29 PM
when using EO IC method you must be quick... I recomend turning the idle speed down as low as possible. ...
Old 05-13-2009, 03:19 PM
I972Nova
I just fell out of my chair laughing Tod! :lol:
I972Nova is offline
Old 05-18-2009, 11:55 PM
jrthone
ok thanks. all that info was no help at all. In the above 8 threads i did not get step by step method. I am new to this and this has wasted alot of my time. If ANY 1 out there has a STEP by STEP Method it would be greatly apreciated.
jrthone is offline
