BBC tuning question?
Old 04-27-2009, 03:32 PM
whitey70ss
Default BBC tuning question?
A friend of mine has a bbc in a jet boat the engine idles fine but as soon as you bring it of idle it starts popping through the exhaust. I tried moving the distributer to the left and it got worse so I tried to the right = worse. I'm wondering if its in the carb its a marine style holley p/n R84018-2 Any suggestions would be helpfull. Thanks
whitey70ss is offline
Old 04-27-2009, 03:48 PM
fatjodycat
im thinking rounded lobe on cam.
fatjodycat is offline
Old 04-27-2009, 06:45 PM
TS1955
Broken or weak valve spring(s).
TS1955
TS1955 is offline
Old 04-27-2009, 09:38 PM
russ67chevelle
running lean???
russ67chevelle is offline
Old 04-27-2009, 10:43 PM
Default Re: BBC tuning question?
why not put a light on it...time it correctly and stop moving it? That would eliminate that variable. Not being a smart alek just a suggestion.
Old 04-27-2009, 10:46 PM
I'd pull the valve covers and do a looky loo.
He's probably got a broken valve spring, broken rocker arm or pushrod not on the rocker arm, been there done that, I hate that sound.
Old 04-28-2009, 02:48 AM
oldandtired
oldandtired's Avatar
x2
I've seen it too many times on BBC marine engines. Dave
oldandtired is offline
Old 04-28-2009, 02:57 PM
whitey70ss
took the valve covers off found a broken spring . I appreciate the help. sorry I'm such a amature ops:
Old 04-28-2009, 03:40 PM
BEAST477
BEAST477's Avatar
Don't be sorry. Everybody has to start somewhere. The easiest way to learn is ask ???
BEAST477 is offline
