ran into another problem
Old 03-16-2009, 08:12 PM
bowhay
Default ran into another problem
ok so now my truck is makin another wierd knock
but it almost sounds like the trans
it will not do it in park or neutral no matter how high it gets revved
and it only knocks when im slowing down wether it be coasting or braking
and it stops once the trans dropps to first
i looked at the trans fluid level to see and it was low so i added a half a quart of trans fluid cus it was all i had, it was till about a quart low at this point
it has a leak from the dipstick as well
please help out
bowhay is offline
Old 03-16-2009, 08:18 PM
radicalz
bowhay....top it off and see if the noise goes away...could be a flywheel or it could be the front pump in the trans....sounds like it might be the pump....but wont know until it is topped off.
radicalz is offline
Old 03-16-2009, 11:36 PM
Check your torque convertor bolts.
Old 03-17-2009, 08:51 AM
yup...it will sound like the mains are hammering if they are loose.
But you could have hurt the bearings with that deal you went through before.
Old 03-17-2009, 09:27 AM
bowhay
idk
i checked the bearings when the motor was out and thats not it
bowhay is offline
Old 03-17-2009, 09:50 AM
itsabird
bowhay this may sound crazy, but you may want to check the alternator, i had a bearing go bad in one, it sounded like all the bad stuff... wrist pin bearings etc, just something to check, good luck.
itsabird is offline
Old 03-17-2009, 11:10 AM
bowhay
how exactly would u go about checking the alternator for that
bowhay is offline
Old 03-17-2009, 11:37 AM
itsabird
take the belt off, or use a ( hose-a-scope) a peice garden hose from the ear aimed toward the alternator, i did both, only in reverse.
itsabird is offline
Old 03-17-2009, 12:17 PM
curtisreed
curtisreed's Avatar
You can also use a long wooden handled screw driver with the metal end on the part in question and put your ear on the handle end. Works great.
I like the hose-a-scope deal.
curtisreed is offline
Old 03-17-2009, 12:21 PM
sm44
i had a flywheel cracked that did the same thing.....almost pulled the motor but checked that first.
sm44 is offline
