th350 trans w/type f fluid
Old 03-06-2009, 05:03 PM
kicker91laser
Default th350 trans w/type f fluid
I bought a th350/10" stall with a mild performance rebuild w/1k on it. The previous owner said he ran type f fluid in it and said he was told that it can withstand the heat better. I have since talked to a few friends who are more involded with domestics than I am and said they have never heard of running type f. Should I continue to use type f in the trans when I install it, or should I drain the trans and converter and swap over to something else? Any suggestions are welcome, thanks guys.
kicker91laser is offline
Old 03-06-2009, 08:11 PM
jmarksdragster
jmarksdragster's Avatar
Synthetics are the best, they don't break down as fast or foam. For a mild street car I wouldn't worry too much, just make sure you have a good cooler on it.
jmarksdragster is offline
Old 03-06-2009, 08:24 PM
I used to put type F in em all the time when I was a teenager ..makes em shift harder( at least I THOUGHT it did :lol: cause someone told ME that) never hurt mine but they were just street trans stuff
Old 03-06-2009, 08:27 PM
proclassmonte
just run dexron fluid, that trans was designed to run on dexron it will give you the best service. I am a transmission rebuilder by trade. synthetics are sometimes a little too slippery.
proclassmonte is offline
Old 03-07-2009, 03:51 PM
lanham
I like to run tractor and transmission hydraulic fluid.
lanham is offline
Old 03-07-2009, 04:18 PM
lookingaround
ive heard that on quite a few different boards. must be something to it.
lookingaround is offline
Old 03-08-2009, 07:32 PM
kicker91laser
Thanks guys, is there a certain brand of dextron that is best to use? Sorry if these are useless questions, I have always been a manual trans guy in the past :?
Old 03-13-2009, 03:12 PM
dimitar
Use Type F.
Type F has a higher viscosity -> better lubrication.
Type F has higher coefficent of friction -> clutches less likely to slip. (also quicker firmer shifts, not that noticeable).
Type F is much better for high performance than Dexron.
If you can afford it, use synthetic.
dimitar is offline
Old 03-13-2009, 10:01 PM
Originally Posted by dimitar
Use Type F.
I've heard that too, I've also heard that B/M quickshift is nothing more than type F. Having said that...lol I put mercon in my powerglide, no problems yet. (2 years running)
I think either type F or dexron/mercon or even tractor hydralic fluids will be fine as long as you buy a name brand, dont get walmart or autozone equate stuff here, pay a few bucks more for the name brands.
Cp
Old 03-14-2009, 06:23 AM
chevyart
Default tranny fluid
i agree with dimitar. use type F. i called all the big tranny companies wthat what i use in my drag car and street car with s 350 turbo in it chevy arthen i rebuilt my tranny (hughes, tci ati and they all recommended type F
chevyart is offline
