366 chevrolet big block?????
Old 02-23-2009, 03:55 PM
bowhay
Default 366 chevrolet big block?????
does anyone know if these motors are any good?
and what they may be good for :?:
bowhay is offline
Old 02-23-2009, 04:28 PM
JimmySmith
Pretty good old truck motor when you compare it to a 327. Later J.Smith 4621 racing :lol:
JimmySmith is offline
Old 02-23-2009, 04:43 PM
THERATTLER
THERATTLER's Avatar
I worked on one in an older motorhome a few years back and the firing order was different than most GM engines :shock: ..don't know why ..just so happened the owner had a manual on the engine that showed what it was..I guess they were trying something different..I don't know if they were all like that or not,,,my 2cents,,,,Paul
THERATTLER is offline
Old 02-24-2009, 05:58 PM
chevynovaman
chevynovaman's Avatar
Default 366
ALL TORQUE, GOOD FOR A BUS OR DUMP TRUCK..... I HAVE ALSO HEARD OF MANY GUYS STROKING THEM BECAUSE THEY HAVE A TALL DECK HEIGHT ALLOWING BIG STROKE...
chevynovaman is offline
Old 02-24-2009, 06:20 PM
bowhay
well i knew it was an old big truck motor, but could one be set up for a racing application
bowhay is offline
Old 02-24-2009, 06:56 PM
fishmanjoe
I never heard of any speed parts made for that block.FISHMANJOE
fishmanjoe is offline
Old 02-24-2009, 08:18 PM
kw89425
the 366 is an odd duck i would spend my money else where
kw89425 is offline
Old 02-25-2009, 04:33 AM
chevynovaman
Default 366
THEY MADE A 427 TALL DECK ALSO, JUST LIKE THE 366 BUT BIGGER BORE.. MOST OF ALL THE BIG BLOCK CHEVY PARTS WILL INTERCHANGE WITH THE 366, BUT THE RODS AND PISTONS ARE DIFFERENT AND THE TIMING CHAIN, THE PISTONS IN THESE MOTORS USE FOUR RINGS, SLOW REVVING ENGINE.. THE CRANK SHOULD BE STEEL AND WILL WORK IN A 396 OR 427 SHORT DECK BLOCK.. THE HEADS ON A 366 ARE VERY RESTRICTIVE, SMALL VALVE,, WHICH PRODUCES TORQUE... GOOD LUCK
