what size fuel pump
what size fuel pump
what size fuel pump do you think i need for my engine combo below?
CAR BUILD SPECS
540bbc/11.8 comp pistons/heads will be done by curtis[pro valve job/c-n-c ported and flowed/i think he said around 445 cc flow but don't remember if that is before or after he works on them]they are brodix 2-plus heads/roller cam with 736 lift 116 LC ;871 stage 4 blower/aly injection bird catcher w/modified square doors]mallory super maglll ign.//trans is PG with 10 disc high gear-stright cut 1;80 planitary-trans brake/4;88 rear gears/spool/32.14.5 slicks/
62 nova wagon built into a 2 door seden delivery with glass doors/front end/guted tail gate-full chassis car with M/S cage[hope to certifie to 7;50/has steel firewall and steel floor with middle trans tunnel and drive line tunnel aluminum/christ alston a-arm front end/ladder bar rear/
CAR BUILD SPECS
I know guys that run Holley blues and blacks with no problem. My advice would be a Magna Fuel 400 or 500 pump. run #10 to the pump, #8 to your regulator, and #6 to the carb. Magna Fuel also has a good billet regulator for around $120.00. I know this way would be no worries!!
You need an Enderle 110 pump that pumps 9.8 gpm or a hilborn -2 which pumps about the same.If you were running gas you could get away with a enderle 80A-1 pump or a hilborn -1 that pumps 6.8 gpm, also with a min. #12, preferrable #14 feed line to the pump and #8 to the injection. You will also have to have a front mounted tank. I run a 3 gal tank, but only run 1/8 mile and drive to the starting line and back to the pits, I use a little less than 2 gal. You may need a bigger tank or tow the car if you plan to run 1/4 mile. But if you plan to run the 1/4 mile i think you'll have to come down on the gear to a 4.10.
If you are going to buy a new one don't let someone talk you into a 990 pump that pumps about 13.8 GPM, it's over kill and a waste of $$$$ unless you plan to add a little or lot of nitro.
