BBC chevy oil pan
BBC chevy oil pan
can someone tell me how important it is to use a windage tray. Is it worth buying another 350.00 oil pan. Running a stroker 496 up to 7500 rpm. On the dyno the oil pressure seemed to fluchate over 6500rpm. Not sure if it is all the oil turbulantes or what. Oil pressure still remained high, but wondering under g force if this will be better or worse and what REALISTIC hp. gains there is with a windage tray? Thanks for some input.
I weld a scupper to the rear of the pan to contain the oil in the sump and prevent the oil from jumping to the rotating assy. The windage tray needs to be fit to your set up. Any thing that keeps the oil in the pan and isolates the rotating Hurricane from the frothy oil will greatly increase the bearing life in your engine. Airation of your oil in a wet sump is a fact of physics. even a dry sump will pump a small amount of air with your oil. The fluctuations you were seeing may have been your oil pump holding air pressure on your oil galley not just oil. If you like your bearings and plan to rev that big stroke in a confined wet sump pan, a windage tray should be as important as your drain plug. In racing engines with 4.5" stroke or more really need a dry sump set up to reliably maintain oil pressure and deminish airation of the oil. The big builders that sell wet sump big stroke engines sell them with wet sumps for COST ONLY, but advise highly to upgrade to a dry sump. Now for your question. YES you should always have a windage tray in your racing wet sump no matter what. The question should be which one should I use. The fit to your rotating assy must be as close as possible to remove suspended oil and keep the oil below protected from the paddle.
There are lots and lots of pans that claim bolt on fit. I would rather buy a good pan with as deep a sump as your chassis can fit, NOT a shoe box style that dragsters use unless that applies, and get a trim to fit bolt in windage tray that you can fit on the stand to get the best performance from your dollars. I guess I am going on and on, Please use the tray, the better the fit the better the performance and the more power you free up. Sorry I went on so long, but your question deserves to be addressed to the extent that you do the right thing for your 09 racing engine. Best of luck
Originally Posted by desoto30
Topspeedlowet.What is your reasoning behind your recommending NOT to use a shoebox style oilpan?
Yep , i made my own dragster looking pan for my street car, added 2 quarts to the front with baffles, If the oil is at all low, when you hit the brakes real hard the oil pressure goes to zero!!!!! At first i was scared, then i just kept drivin, its done it more times than i can count and still runs and great oil pressure! Lol... Its the Mavel Mystery oil keepn the engine alive
I've got one of those high dollar pans and titan pump for sale for a genIV blk. it wouldn't fit our door car with a cross member. About 1300.00 worth for 600.00 if you or anyone else is intrested, PM me.
