BBC Electric Water Pumps
Old 01-11-2009, 07:45 AM
jreiley
Default BBC Electric Water Pumps
I see lots of ads for electric water pumps. Any suggestions on the one to buy for a bbc drag car?
jreiley is offline
Old 01-11-2009, 07:54 AM
TopspeedLowet
I have had a few different brands and the Meziere pump I have has been in service for over 4 years and flows like a belt driven pump. The finish and quality is obvious when you have one in your hand. They come apart rather easily for any servicing you might need without any trade tools.
TopspeedLowet is offline
Old 01-11-2009, 07:57 AM
slowmotion
I have the shogun remote pump. Works good but better have an extra impeller just in case.
slowmotion is offline
Old 01-11-2009, 08:08 AM
ashtrak
Which ever one you choose i would go with a high flow piece. IMO
ashtrak is offline
Old 01-11-2009, 08:10 AM
CSR for me
Old 01-11-2009, 08:15 AM
TopspeedLowet
Alot of guys jump over that fact. The high flow pump will back up pressure in the block and heads behind your restrictor and raise the boiling point further to eliminate hot spots in the head.
Old 01-11-2009, 03:13 PM
tcarda
I have used a CSR for 3 seasons without any problems.
tcarda is offline
Old 01-13-2009, 10:02 AM
jreiley
Thanks for the help.....
jreiley is offline
Old 01-14-2009, 04:55 PM
russ67chevelle
i have a mezere,but i see jegs has a line of them too
russ67chevelle is offline
