motor overheats..please help
Old 01-06-2009, 05:37 PM
rechek5
Default motor overheats..please help
i run a street stock class on a small small 1/4 mile so were not going very fast which means not much airflow
motor is pretty much a stock chevy 305 i run a hei dist. and a 2bbl rochester carb
radiator is a 3 core gm radiator
i have tried both electric and manual fan with shrouds..
i cant run a whole feature event without the motor getting so hot it pushes most if not all the water out of the radiator... please help
rechek5 is offline
Old 01-06-2009, 06:14 PM
fla1976
fla1976's Avatar
Default Overheating
Check to make sure your radiator cap is good. If it is weak or leaking it will cause the water to boil at a lower temperature.
fla1976 is offline
Old 01-06-2009, 07:17 PM
lookingaround
what about a thermostat or restrictors in the thermostat housing to slow the circulation so it can cool it
lookingaround is offline
Old 01-07-2009, 02:48 AM
itsabird
try back filling the engine, makeing sure there is no air in the system, and if you are not useing it now, try water weter, good luck.
itsabird is offline
Old 01-07-2009, 03:02 AM
TopspeedLowet
Have you concidered that the cam timing is too advanced. This is a common problem with many stock chevys using towing cams. The other likely player would be a EGR that never shuts off. Sometimes the EGR gets hooked up to a vaccume source that keeps it active under full power. That will cook the intake and cause the engine to run lean. Then are you possibly running real lean?
Food for thought..........
TopspeedLowet is offline
Old 01-07-2009, 05:50 PM
rechek5
have tried water weter
have tried a thermostat and reducer
plugs actully looked a little on the rich side
and cam is a comp 260h and degreed to what comp wants it at
rechek5 is offline
Old 01-07-2009, 11:58 PM
Like above mentioned I'd try a new 15 to 16 psi cap first -thats a cheap fix.
Other thoughts....
I'd go with a bigger raditor if the rules allow, you might also consider a aluminum one if you can spare the change, they really make a difference.
Also a aluminum high flow water pump will make a big difference too - they can be had for around 50 bucks just about anywhere, I got mine from a vendor on here.
Goodluck, Charles
Old 01-08-2009, 09:39 AM
kwkracing
either the water pump isnt pumping, maybe the shaft broke off, maybe its full of rust or the thermostats stuck.
kwkracing is offline
Old 01-08-2009, 04:21 PM
demo1976
i dont have any ideas for you to try but i also run a 305 with a 260h comp 2bbl and hei.. our motors are almost twins.. lol
demo1976 is offline
