tall deck bbc help
tall deck bbc help
i am switchin to a 10.2 deck 598 i have dart 345 heads (i believe are to small?.) my questions are do i need a different intake ....i think the dist is different anythin else u can think of
what block are you using?as to intake you will need a intake for tall deck bbc OR if already have a intake for std. deck bbc then you can use it by using intake spacers.the dist also needs to be for tall deck or one with adjustable collar..on lifters they need to be .300 taller on my dart block[10.20deck]according again to what block you are using.check your cam location..on the dart big M block[as i have]they are in stock location but i've heard of some block having cam raised.if a dart[as i have]then you use std gear drive or timing chain or belt drive for any bbc mark iv's..
Re: tall deck bbc help
thanks for the help the block is a bowtie.......any ideas on a good intake for this combo....should i try to sell the 345's or can they be made to work?....
lets see cam is not purchased yet open to ideas.....heads are out of the of dart 345 block is a bowtie tall deck ..crank is lunati pro mod 4.500 stroke.. rods are eagle 6.800 pistons are je 4.600 bore this motor was a shfiroff 598 built in 03 and hurt a rod in 06 then set in a buddys garage til igot it last year he has the cam that was in it ...it came from shafiroff with dart 360 heads which he kept..for his 632 t is going in my 215wb four link dragster.....if it builds enough steam i will run the top dragster series at lebanon valley and epping nh if not i will just bracket race it ....
