help on rim size
Old 11-25-2008, 04:32 PM
hotrodlincoln2
Default help on rim size
would a 1998 c5 z06rim fit on a 1988 iroc ? :?:
hotrodlincoln2 is offline
Old 11-29-2008, 03:55 PM
the bolt pattern should be the same( chevy pattern 4.75)..measure this to be sure ( middle of bolt hole to middle of bolt hole diagonally) ..what you need to be concerned with is the back spacing. Measure this to be sure. the Z-O6 is a pretty wide wheel.
this thread will help explain how to properly measure the wheels if you don't know how already
https://www.rsracing.com/tech-wheel.html
