PCV Question
Old 10-06-2008, 09:31 PM
A96LT1355Z28
Default PCV Question
Does anyone use anything like this?:
http://store.summitracing.com/partde...5&autoview=sku
I currently have an inline filter (air/oil seperator) in my pcv system but I was thinking of eliminating it all together for a system like this. I've been told it can free up some more power. Is there any negative impact on this type of setup or is the "drag race use only" disclaimer for emissions?
Thanks,
Josh
A96LT1355Z28 is offline
Old 10-07-2008, 06:40 AM
A96LT1355Z28
OK, I posted a link to Summit that works this time! Sorry!
Old 10-07-2008, 08:28 AM
john858
i've used them for years & i like them pretty well,just switched to a vac. pump and its great. i would try them if i where you they aren't going to hurt nothing.jmo good luck,john
john858 is offline
Old 10-07-2008, 03:54 PM
johnracer
It is a race only part as it relies on unrestricted exhaust flow to work. I'm pretty sure that mufflers will cause enough backpressure to prevent them from working....
johnracer is offline
Old 10-07-2008, 04:49 PM
A96LT1355Z28
Thanks, that's what I wanted to know. I've seen em on race cars but never on cars that see any street time. I have 3" exhaust into a 1 chamber Flomaster turned down under the rear right seat. It sounds like these are more for higher rpm open header setups.
Thanks, :wink:
Josh
