Motor Freshen Up
Old 10-05-2008, 03:58 PM
Default Motor Freshen Up
Hey guys its that time of the year, time to freshen motor up. I will be doing some calling/shopping around more this year being I have a bit more time then normal to get it done.
What do you guys pay/think is a fair price for the following.
DISSASSEMBLE AND CLEAN
DO A VALVE JOB
HONE BLOCK
INSTALL NEW BEARINGS, RINGS ALL GASKETS, TIMING SET,
LIFTERS
SPRINGS
REASSEMBLE AND DYNO TEST
Old 10-05-2008, 05:00 PM
Just a thought..if your compression check is good why go thru all the above.
If i were you i would change out springs/retainers/keepers, check the valves themselves.change out lifters
drop pan and take a peek at your bearings.if they look good then roll with it...
Do it yourself free labor
all for say $600.00 or under ?
this is only my opinion David..9x's out of 10 if something goes wrong its in the above stuff i mentioned anyway
i would try it anyway..you can always go back and spend money anytime you like.. 8)
Old 10-05-2008, 05:10 PM
Brian thanks for the input I always take everything in and ponder what I need to do. I do the freshen up thing yearly now because i dont want to chance the high $$ motor, guess its cheap insurance. I have 250 + passes on the motor this year, some with nitrous. paranoid I suppose
Old 10-05-2008, 05:19 PM
hey thats good to..don't blame you either way..
you do put more passes on a car then most...with alcohol also.....
Nye's not helping you out a little w/fresh up price ? if not they should be with all the business you give them and advertising.
IMO
Old 10-05-2008, 05:33 PM
IMO
well you'd think they would huh :wink:
I wouldnt even be shopping around but they are more then busy at the moment. May still take it to them and wait but just want to shop around a bit, never know untill I look I suppose. I gave up on doing my own when I went to big blocks a few years ago before that we always did them. Figured this HP and pricey stuff be a good idea to start letting someone else do them for me.
Old 10-05-2008, 05:40 PM
lively
lively's Avatar
DAVID--I WILL PUT NEW PAINT ON YOUR MOTOR/REPAINT THE HEADS AND SPRAY ROOM FRESHENER ON THE WHOLE THING --THIS WILL MAKE IT REALLY FRESH---FOR THE UNBELIEVABLE PRICE OF $99.99.
BY THE WAY I SUB MOST OF MY WORK OUT TO "TOTRADE" BECAUSE HE IS SOOOO HONEST WITH ME!!!
LIVELY-----ONLY KIDDING GUYS!!!!!!!!!!!!!!!
lively is offline
Old 10-05-2008, 05:44 PM
michael1
LOL Thats a good one lively.
michael1 is offline
Old 10-05-2008, 05:58 PM
michael1
hammertime I sent you a pm,did you get it?
michael1 is offline
Old 10-05-2008, 06:12 PM
No pm yet ?
Old 10-06-2008, 05:34 AM
bbchevy
Default Freshen
Hey Hammer,
Heres a GOOD Guy rite here in our,Your Area?
C-Tech Performance
Wyoming,Mi.
www.c-techperformance.com
Arnie Snyder
Give Arnie a call,He can Help!And also has in House Dyno Service
Later
G 8)
bbchevy is offline
