goodyear slicks
Old 08-10-2008, 04:41 PM
br1984
Default goodyear slicks
info needed been haveing trouble planting right rear tire race last night 60 foot was up and down seen today my tires dots are gone from middle to in side the rest is abought 50% worst on right side could houseing be bent has fab 9inche ? or
br1984 is offline
Old 08-10-2008, 04:53 PM
shawnp
That is possible or it is possible the rear is not in square. I have never had a side wall issue that shows what you are seeing with the GY but have with M/T tires.
shawnp is offline
Old 08-11-2008, 03:43 AM
sg1586
unequal bite??? Does the car lean way over to one side??
Hove any vid of the back of the car on the starting line....This will help us help you..
sg1586 is offline
Old 08-11-2008, 01:38 PM
br1984
no the car leaves even i posted wrong the slicks aer hoosiers not goodyears sorry
br1984 is offline
Old 08-16-2008, 06:17 AM
onedragracer
Have someone video your car making a pass. You can slow down the video while you watch it and that should help you find your problem. I bet your rearend is not square with the chassis like the guy above mentioned.
onedragracer is offline
Old 08-23-2008, 07:58 AM
dparker
You said dot tires. Do you drive this car on the street? If so, and you have a spool, everytime you turn one tire must slip, even if your turning slow. And while your turning your car is applying more weight to the outside.
dparker is offline
Old 08-24-2008, 12:21 PM
Bamfster
do you mean the wear indicator "dots" are gone? If so, that is a common symptom ( inconsistent 60" ) of worn out slicks.
Bamfster is offline
Old 08-25-2008, 03:14 PM
br1984
yes but there just gone on inside never had a set do this before from center out still good
br1984 is offline
Old 08-25-2008, 03:46 PM
itsabird
how much air pressure are you running?
itsabird is offline
Old 08-25-2008, 05:32 PM
br1984
most of the time 61/2pounds
br1984 is offline
