1150 dominator no power valve?
Old 07-07-2008, 01:49 PM
CHEVYMATT
Default 1150 dominator no power valve?
i bought a 1150 hp dominator from a swap and it looks in good condition. i dont recall the numbers but it did come up as a 1150hp
anyway i removed the bowls to check power valves and jetting and found front 84 with no power valve hole at all and rear 86 with no power valve hole at all. it is not even an option .. is this common on the 1150 hp's.or do i have two rear mettering blocks on this carb it also has progressive linkage..
thank you
CHEVYMATT is offline
Old 07-07-2008, 04:54 PM
jmarksdragster
jmarksdragster's Avatar
No power valves. Those jets are low for an 1150, 92 to 99 depending on the model #. Check here for factory jetting and start there.
http://www.holley.com/data/TechServi...%20Listing.pdf
jmarksdragster is offline
Old 07-07-2008, 07:21 PM
CHEVYMATT
Default thanks
thanks for the site it will come in handy
Old 07-07-2008, 08:18 PM
jmarksdragster
Here is some more to swallow.
http://speedtalk.com/forum/viewtopic.php?t=9934
http://www.motorsportsvillage.com/fo...pic.php?t=3283
http://www.motorsportsvillage.com/fo...pic.php?t=3742
http://www.motorsportsvillage.com/fo...pic.php?t=3811
