nos fogger problems
Old 05-05-2008, 05:40 AM
michael1
Default nos fogger problems
I have a tunnel ram that someone drilled for a nos fogger system but they had every hole stripped out. Is there any way to fix this without welding the holes up and starting over? I know BG makes a npt reducer bushing, has anyone had this problem, if so how did you fix it? The holes are 1/8 inch so I can go bigger. Thanks for any help you give.
michael1 is offline
Old 05-05-2008, 06:21 AM
v8Fiero
that sucks, you can either get new thread inserts or use an adapter like they give you with universal shift knobs. both work the same basic way and shouldnt disrupt flow much more then before. be sure to seal them up tight with thread sealent glue.
v8Fiero is offline
Old 05-12-2008, 08:39 AM
racecrafter
If you can find heli-coil inserts in the proper thread they should work as long as the holes havent been made too large. once again use sealer....no teflon tape!!!
racecrafter is offline
