Tall Deck Question
Old 05-03-2008, 09:17 PM
blaserman
Default Tall Deck Question
What distributor do you use in a Tall Deck , will a normal big Block
Dis work in a Tall deck.
blaserman is offline
Old 05-03-2008, 09:27 PM
michael1
It depends on what intake manifold you have
michael1 is offline
Old 05-03-2008, 09:42 PM
The tall deck requires a longer distributor shaft from the lockdown collar. If you use an MSD and some other aftermarket distributors they have an adjustable slip collar on them. Drop the distributor until it bottoms out on the oil pump drive then raise it up 1/16" and lock the clamp collar. some manifolds come counterbored for the tall deck but they require a spacer for a regular 9.8 deck block. Tall deck is 10.2 height.
Hope this helps.
Old 05-04-2008, 02:32 AM
sc3314
Default Dist
Zip hit right on for a slip coller dist set up. There are some intakes that are machined for a T/D block where you can run a standard dist with the T/D
sc3314 is offline
Old 05-04-2008, 05:51 AM
blaserman
Default Distributor
thanks that answered my Question
Old 05-04-2008, 06:45 AM
topcat572
Default td
I ran and untill now I am changing the TD Dart off my BB. Dart said its machined to accept a standard height dist, WRONG. As far as the MSD crank trigger dist I tried to run, and machined it for a slip collar, it was still too short. Had to go tall. Good luck.
topcat572 is offline
Old 05-04-2008, 09:06 AM
dcarr511
I used a Weiand Team G for a Tall Deck and a stock length distributor .... so it depends on which intake you decide on and if its cut for a stock dist.
dcarr511 is offline
Old 05-04-2008, 11:14 AM
bbchevy
Default Manifold
My Tall Deck DART Tunnel Ram,used a Standard Deck Dist.This was a High Dollar T/Ram about 1100.00 new.And,i was Definatly a 9.800 Deck Height Dist.even though i run my Mag off the Front of the Motor,i still have a Oil Pump Drive in place of the Stock Dist.
When i Called Dart,i was told that all of there Manifolds where machied for a 9.800 Deck???
Maybe,your manifold went out the Back Door?
Later
G 8)
bbchevy is offline
Old 05-04-2008, 11:29 AM
topcat572
Default TD
Just got the intake off the car a little while ago, still have the origional dist if any one wants to try them,lol.
