Lifter bore problem
Old 03-15-2008, 09:45 PM
altune
Default Lifter bore problem
I need to find out how much lifter bore clearance is acceptable. I had some issues with low oil pressure in a race engine of mine and one of the lifters got a bit stuck in the lifter hole. I had to use a pry bar to remove it and it looked scorched.
I dont want to throw the block away but may have to.
any easy fix for these?
Al
altune is offline
Old 03-16-2008, 05:31 AM
hink
Default Re: Lifter bore problem
Al
What engine are you talking about and what lifters ???
hink is offline
Old 03-16-2008, 02:35 PM
altune
block is sbc 509 casting.
lifters are solid roller, crower I think.
Al
altune is offline
Old 03-17-2008, 08:41 AM
hink
Al
The lifter bores in that block can be bushed back to standard bore or they can be machined to .875 and no bushings or even .904.
hink is offline
