N.O.S. help
If you are using a "small" shot Alky will not be a problem as you increase the quantity the temp of the intake mixture can go low enough that fuel atomization can become a problem...I can be more specific if you give a little more info about your setup and how much you nitrous you wish to add.
well as strange as it may sound we are putting it on a jr dragter.i was also looking at putting a dry set up on it. and just bumping up in main fuel jet size.the set up is from dyne tune.for a 4 stroke quad with a 9hp or 15hp shot.just wanting a little more out of it.and like always go FASTER.
