correct rear gear
Old 02-14-2008, 04:51 AM
nova2206
Default correct rear gear
I have purcased a new car and want to know what gear would be better.The car is a square tube chassis Camaro that will weigh right at 2450 lbs with me in it, the motor is a sbc 383 stroker with about 650hp and I'm using a power glide with a 1.82 firts gear and a 55oo stahl converter..The rear is a narrowd 9 inch with a 31x10.5x15 tire..What gear would be best..??
Thanks
nova2206 is offline
Old 02-14-2008, 06:55 AM
OneBadGMC
Kinda need to know redline on the motor...
But, I'm thinking 4.88s or 5.13s.
OneBadGMC is offline
Old 02-14-2008, 09:17 AM
nova2206
I usually don't go any higher than 6800, shift at 6400
nova2206 is offline
Old 02-14-2008, 09:29 AM
5.14
Old 02-14-2008, 12:50 PM
signsbyesa
yea the 31" tire will work great with the 5:14 ratio :wink:
signsbyesa is offline
Old 02-14-2008, 06:55 PM
cncmotorsports
Try this calculator http://www.richmondgear.com/101032.html
cncmotorsports is offline
Old 02-14-2008, 11:52 PM
I would think where you'll be racing most would be a factor.
I.E> 1/4 verses 1/8?
If the 1/8 I would start out with a 513 and see what the motor likes, maybe up to a 538 or down to a 488 remember the more motor you have the less gear you need, but likewise the less gear you have the harder on parts it will be.
In the 1/4 I'd start out with a 430, or 456 and go from there to see what the motor likes and where the rpms are in the traps. But what do I know.
Goodluck, Charles
Old 02-15-2008, 04:46 AM
Originally Posted by cepx111
Racecar spelled backwards is, racecar.....
haha...never noticed that b4.
