tire rotation
I rotate mine every 15-20 runs. More often if they grain heavily. I think Goodyear reccomends that you mount them with the branded sidewall to the right side of the car on both slicks. Rotate them and make a few passes then put them back. They'll definately last longer....
That would be heavy. Looks like waves running across the tire. It usually starts on one edge and moves across. You'll need to rotate them before it gets that bad. They wear pretty fast once they start to roll rubber. If they look like sandpaper, you're fine. When they start to develop little waves, you might consider rotating them...
