Mastang Looses Belts
Old 01-17-2008, 10:26 AM
bsahall
Default Mastang Looses Belts
Any body got any ideas about how to keep an alternator belt on at 7500 rpm's? I have a 351 windsor in a Fox Mustang, running an electric drive on the water pump, no power steering or A/C. I need bracket ideas for the alternator to keep the belt from flying off. Thanks.[/i][/b]
bsahall is offline
Old 01-17-2008, 04:09 PM
fla1976
fla1976's Avatar
Default Alternator belt
You could try changing the alternator pulley to a larger diameter one. Check the belt for alignment.
fla1976 is offline
Old 01-17-2008, 04:16 PM
if you do not have the DEEP GROOVE race type pulleys you will continue to have the problem...also when you put on the DEEP GROOVE pulley make sure you get a COG belt the sits way down in the pulley groove..once the belt sits down in the groove you should see sides of the pulley coming up above the belt...this will 99% solve your problem.
Keep in mind stock type pulleys and stock fitting type belts were not designed for turning 7500 rpm's.
Old 01-19-2008, 12:09 AM
olds48
Run a belt that is as short as you can possibly run.Helps a lot
olds48 is offline
Old 01-19-2008, 03:08 AM
I would recomend a serpetine belt set up, they tend to stay on with the higher rpms engines like yours. You can get a later model alternator and brackets from a donor car at a local bone yard. I also think jegs and summit is conversion kits too.
Goodluck
><Charles
