Just built one. 406, Scat cast steel crank, Scat H-beams, Srp pistons, Pro-1 Platinumn 230's with a bit of work, mild solid roller, Super Vic, QF 950carb. 615hp and 540 ft/lbs on pump gas
I had a sbc stroker built with Compstar components and I was pretty happy. It's made overseas but final machining is dome by calais.
4" stroke 4.155 bore is a good combo. compression should be no more than 10-1 for pump gas, Brodix track ones ( cnc) should make 650 hp on that setup.
Al
are you wanting to stroke it- or (de)stroke it?
like a 400 chevy crank in a 350-
or a 350 crank in a 400- with a long rod ,and custom pistons?
a 350 is only borable to how much? :idea:
