Where Can I Find A BBC to SBC Front Adapter Motor Plate.
You'll probably have to get one made for you. I fabricated spacers to go between the rear of the big block tabs on the chassis and the front of a straight small block motor plate. Looked and worked fine. I can email you a pic or I'll post it here if someone can tell me how....
You can email me a pic. to [email protected]
Any sheet metal shop shoul;d be able to fab that up from scratch for you. It shouldn't be that big of a deal. Just tell them how much of a Z you need on it.
You can also buy a semi-finished SB Plate for a wider frame than you have and get the sheet metal shop to just make it to be offset like the one you want. You are just talking about 4 bends at a 45 deg angle. Then fit the rest to your car. It does look cool though.
Ed
Ed
Tommy makes the motor plates you need, as well other stuff like trans shields.
http://www.racecarpartsdepot.com/tra...n-shields.html
