going from gas to alky
Old 01-04-2008, 02:11 PM
jerryms
Default going from gas to alky
i would like to convert my motor to alky from gas,388sbc 1050 dominator 14.8 to 1 is it easy?thanks
jerryms is offline
Old 01-04-2008, 06:17 PM
jrdragsdad
call george ruppert 1-931-372-9142
jrdragsdad is offline
Old 01-04-2008, 09:48 PM
davis419b
Yes it is easy! Just a big piece of advise. If you are currently running gas from a plastic fuel cell , REMEMBER if it has foamy looking baffle in there make sure you take it out. If you dont the alcohol will turn it to jelly and gum up everything!!! Don
davis419b is offline
Old 01-05-2008, 02:21 AM
X2
Very easy to do, I think alky dominator will be to big though.
www.apdracing.com one of the best carb shops anywhere !!
Old 01-05-2008, 09:28 AM
jmarksdragster
jmarksdragster's Avatar
BLP carbs is another. Very good work, been in business a LONG time and they make almost everything in house. They also supply a lot of other companies with components for Holleys.
jmarksdragster is offline
Old 01-06-2008, 03:31 PM
thetanman101
X2
-Tanner
thetanman101 is offline
Old 01-06-2008, 03:33 PM
thetanman101
BLP also carries a belt drive fuel pump with an internal resevoir (sp?) and fuel regulater. This means no inline regulator is necessary, and no return line to the fuel cell is needed. This piece is the cat's a$$!
-Tanner
Old 01-06-2008, 03:53 PM
davis419b
X 3
I have both 1250 Carb & Belt Brive Pump .04 quicker than Rupert. Dont get me wrong nothing wrong with Rupert . I had a Rupert 1250 but this is much faster and runs so clean .
