Need Some Tech help with hard starting Motorcycle
Old 11-06-2007, 05:27 AM
wlpatterson
Default Need Some Tech help with hard starting Motorcycle
I just purchased a Titan Gecko 113ci/115hp with a S&S engine thats really hard to stsrt--I know alot of its because of the hi compression but noway it came that way--Im wanting to know if they came with a special hi torque starter & someone has changed it? I really appreciate any help anyone can provide--I did contact S&S and am waiting for a reply,Maybe they can solve it for me--
wlpatterson is offline
Old 11-06-2007, 03:29 PM
dragharley1
sometimes the have compression releases,or you could upgrade to aspikestarter
jim
dragharley1 is offline
Old 11-07-2007, 05:19 AM
wlpatterson
Default Starter
What is a spikestarter?
Old 11-07-2007, 12:19 PM
dragharley1
spyke is a brand of starter ...top of the line
Old 11-11-2007, 03:58 PM
a13badazztoys
Ive seen this problem traced back to a bad start relay or the wrong start relay amprage..if you do a cranking compression test and it isnt over 160lbs then compression releases wont do the trick but do make things a whole lot easier on the starter.. :lol:
a13badazztoys is offline
Old 11-11-2007, 04:40 PM
lookingaround
i thought if they were over a 100 ci they came with compression releases. just what i was told
lookingaround is offline
