Holley 650 cfm marine quadrajet replacement carb
Old 06-14-2007, 01:23 PM
CHEVYHIGHLIFE
Default Holley 650 cfm marine quadrajet replacement carb
Anybody use one on the street, will it work out of the box or does it need re-jetting?
CHEVYHIGHLIFE is offline
Old 06-14-2007, 02:59 PM
alscoupe
I've used plenty of spread bore's outta the box. They'll work just fine on stock motors, with a little tweekin'. Not sure what's special about "marine". Any mod's in the motor and it'll be "tune to fit".
alscoupe is offline
Old 06-14-2007, 03:47 PM
CHEVYHIGHLIFE
I read on holleys site that marine carbs are tuned for constant load, automotive carbs are tuned for variable loads. Dont know if that makes much difference?
Old 06-14-2007, 04:59 PM
alscoupe
OUCH, fraid it might be something like that. Metering blocks and power valve differences. Make it "stumbble" off the line. Might run fine wide open, if it were race only.
alscoupe is offline
Old 06-15-2007, 02:09 AM
CHEVYHIGHLIFE
thats what im thinking too :?
