alternator help
Old 05-11-2007, 06:57 PM
slowman
Default alternator help
does anyone know a good alternator guy or biz ?
slowman is offline
Old 05-12-2007, 03:44 AM
sledgehammer
To buy an aftermarket alternator?
sledgehammer is offline
Old 05-12-2007, 08:50 AM
slowman
hey sledgehammer, i need a 1 wire that will charge well i'm driving on the street at low rmps. i haved tried just about every brand with no luck. i seen somewere that a guy says his will and i can' remember were i seen it. it was someone doing it out of a small shop or his house. i have put a volt meter on alot of alternators and none of them are charging below 2500rmp. if anyone has any info please help.
slowman is offline
Old 05-13-2007, 04:57 AM
oobob
What size crank pulley are you using?
Mine with a 5" charges fine while cruising, it's just the 1 wire cheapo chrome alt from Summit.
Mark
oobob is offline
Old 05-13-2007, 09:37 AM
slowman
thanks oobob, as good as i think i is only shows how dumb i is :lol: lol. good point i will change the pully and see if that helps. thanks again for pointing out the easy fix :lol: lol. the only thing i have to say is you should have fixed this for me last yr :lol: :lol: :lol: :lol:
slowman is offline
Old 05-13-2007, 10:09 AM
lively
lively's Avatar
SLOWMAN!!!!!!!!!!!!!!!!!---DID YOU EVER GET A TOE STRAP AND REV LIMITER FOR YOUR CARS???????---WE DON'T WANT YOU GRIPING NEXT YEAR THAT WE DIDN'T HELP YOU OUT!!!!!! :roll: :roll: :roll: ---YOU ARE FOR SURE GETTING OLDER :shock: :shock: :shock: :lol: :lol: :lol:
lively is offline
Old 05-13-2007, 12:30 PM
slowman
lively, i have been knowen to have a brain fart from time to time but this one may be the biggest lol. i do have a tow strap and rev limiter and i don't think your very funny. :lol: :lol: :lol:
slowman is offline
Old 05-13-2007, 01:10 PM
lively
lively's Avatar
YOU KNOW IT IS LIKE THE TIME I CHANGED MY OIL IN MY CREW CAB AND STARTED THE ENGINE TO LET IT BUILD PRESSURE AND THEN NOTICED THE 5 QUARTS SITTING ON THE FENDER!!!!!!! :roll: :roll: IT WAS NOT HURT BUT!!!!!!!!!! STUPID ANYWAY ops: ops: ops:
lively is offline
Old 05-23-2007, 08:59 PM
slowman
the pully didn't work but i figured it out. i bought a painless power star and it's all better. ten alt later and one works go figure.
slowman is offline
