Results 1 to 3 of 3
Thread: SBC how much cam can I get in 9.25 deck block with 4 inch stroke 6 inch rod
  1. #1
    Junior Member SHOW GUEST
    Join Date
    Aug 2007
    Posts
    1
    I'm building a 440 cubic SBC and it has a 4.00 stroke 6.00 rods 4.185 bore I run a .900 base Circle solid roller cam and would like to get 850 to 900 lift just wondering if it will fit in my combination without hitting connecting rods thank you
  2. #2
    Senior Member RACING JUNKIE curtisreed's Avatar
    Join Date
    Feb 2004
    Location
    KIEFER, OK.
    Posts
    1,311
    You can look at the Callies Ultra offset rod to help. Also consider the lobe you will need to get .900" lift. You will probably have to have a bbc journal cam I believe to get that much lift in the block even with 1.7 rockers. At .900" with 1.7 rockers it is a .529 lobe.
  3. #3
    Senior Member MASTER BUILDER
    Join Date
    Mar 2014
    Posts
    207
    I have a 50 MM camshaft that is .850" with 1.8 rocker ratio.
    It was in a 9.325" block and raised cam.
    It had a 4.125" stroke crankshaft and 6.125" Callies Ultra rods.
    Also have a timing cover and timing chain set to go with it.
    [email protected]
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Copyright © 2005-2016 RacingJunk.com All Rights Reserved.
Designated trademarks and brands are the property of their respective owners. Use of this Web site constitutes acceptance of the RacingJunk.com
Terms of Use, Classifieds Disclaimer, Privacy Policy, and Cookie Policy
