-   -   BBC Intake gasket I.D. help (https://www.racingjunk.com/forums/showthread.php?t=26888)
dynaguy03 01-02-2010 04:58 PM
Hello ..I have a "new to me 582 on Alcohol" i removed the intake and the gaskets have no numbers on them.
This motor has Dart 360 heads- Dart intake.. doesnt look like any exotic work just clean up on ports. Doesnt look like double thick gasket .
What intake gasket #'s would i use. In the past have used Cometic gaskets and really liked the quality. But i have no idea what part number to ask for.. i prefer to spend extra on good gaskets.. i hate to do things twice.
Any help would be appreciated!!
Thanks
Keith
TS1955 01-02-2010 07:23 PM
If you want to use a conventional gasket, a Fel-pro # 1275 should work fine.
TS1955
RonOwensRacing 01-02-2010 09:00 PM
The fel-pro's do work good and you may not beleave it but so do'es the
5828 - Mr. Gasket Ultra seal Intake Manifold Gaskets
I use these on a alky injection engine for the last 7 years
hammertime 01-03-2010 05:11 AM
The fel-pros are ok but the Cometic intake gasket is much better IMO
Ron you've been very lucky with the Mr.Gasket stuff, I learned long ago them gaskets eventually dry rot from alky...I fought that for 3yrs before I switched.
cepx111 01-03-2010 09:14 AM
X3 ---> felpro 1275
dynaguy03 01-03-2010 03:07 PM
Gaskets
Thanks everyone!
David would you know a cometic part number for the said gasket by any chance?
Thanks
Keith
RonOwensRacing 01-03-2010 08:28 PM
May have been then but i have ran them for years no problems i also run the Fel-pro's the Mrg gaskets are on there right now.
Like i said the fel-pro's are good i just haven't had a problem with the ultra seal Mrg's.
dynaguy03 01-04-2010 09:39 AM
GASKETS
THANKS ALL!!..
i ORDERED THE COMETICS.. GASKETS.. I gave them the fel pro 1275 # and they crossed it to there number.
Thanks Again
Keith
Pwmax 01-04-2010 02:52 PM
I would get the 1275-S3's. They are the same gasket, but they have a metal core. One other thing I have noticed with the 1275's, vs the s3's, is the area around the water port, there is more gasket below the water port. Some heads, have very little material where the gasket sits on, and intake water leaks can occur. The s-3's eliminate that.
Frank
