i remember zip his user name was arussell. and the thread was je piston tech. august 2008
I also remember the topic, I didnt run them before that either though.
Kod, is there any other engine builders or is this someone you've dealt with for years ? |
Hey David i ran them once, but never again, in fact i now build with Probe pistons, cheaper than JE, wisco or anyone else and the same 2618 mat'l for a true forged piston. JMO Zip. |
Kod, is there any other engine builders or is this someone you've dealt with for years ? And on the dyno, this engine kept 8 inches of crankcase vacuum while running gas and built 24 psi pressure on alcohol. I run a HV billet oil pump and he figures maybe it's putting out too much oil and flooding the valve train area. He mentioned putting oil restrictors in the block to limit the oil getting to the top end. Initially he thought we needed to speed up the vacuum pump to get rid of the crankcase pressure, which I havent tried yet as I just received the new drive pulley yesterday. We don't have as many engine builders to choose from in the Great White North. I am just about ready to get this engine running right on gas, sell it and order a Steve Schmitt engine. |
Did you get a chance to leak it or compression it yesterday ?
If you do bail on this engine and go another route, there is better shops to choice from then Schmidt also :wink: |
Milky oil
I believe SRP pistons are 4032 alloy for small blocks and flat top BBC but are 2068 for high compression BBC. I have 2 sets of 496 pistons here and it says on the box and paper work they are 2068. They are a little heavier than the JE and less compression 12.7 versus 13.5 but other than that they are just $200 cheaper.
Are your gapless rings top land or second land gapless? Top gapless should leak 2%. Have you talked to a tech guy at TOTAL SEAL about rings? Has your engine builder? I have built some alcohol engines both naturally aspirated and blown and the rings and cylinder wall prep was only difference per TOTAL SEAL specs. I have had to file fit gapless rings as they were not in the range of .010"-.040". I have also had a guy switch back and forth on a carburated engine and saw no differece as far as blowby. His engine did not have gapless rings. |
If you do bail on this engine and go another route, there is better shops to choice from then Schmidt also :wink: I plan on doing it today if I can find enough time. |
Re: Milky oil
Re: Milky oil
Are your gapless rings top land or second land gapless? Top gapless should leak 2%. Have you talked to a tech guy at TOTAL SEAL about rings? Has your engine builder? I have built some alcohol engines both naturally aspirated and blown and the rings and cylinder wall prep was only difference per TOTAL SEAL specs. I have had to file fit gapless rings as they were not in the range of .010"-.040". I have also had a guy switch back and forth on a carburated engine and saw no differece as far as blowby. His engine did not have gapless rings. Zip. 2068 alum. R.R.56 [1] Melting point 635°C Density 2.75 Composition Copper 2.0% Nickel 1.3% Magnesium 0.8% Iron 1.4% Titanium 0.1% Silicon 0.7% Aluminium 93.7% 2618 alum Chemistry Data : [top] Aluminum Balance Copper 1.9 - 2.7 Iron 0.9 - 1.3 Magnesium 1.3 - 1.8 Nickel 0.9 - 1.2 Remainder Each 0.05 max Remainder Total 0.15 max Silicon 0.25 max Titanium 0.04 - 0.1 |
Milky
Sorry guys, but I mis spoke on the SRP alloy for BBC high compression. It is not what I said. It is 2618 just like JE. Also it is not on the box but is in the literature. Oops.
If you do bail on this engine and go another route, there is better shops to choice from then Schmidt also :wink: Cold Compression test: 195 to 218 psi Leak down: one cylinder at 0% and one at 2%. All the others at 1%. Hot - 160 degrees Leak down: 3 cylinders at 1%, 4 cylinders at 2% and one at 8%. I changed to oil after the tests. It looked good. No milking. Warmed the engine and checked the valve lash. All were good. The oil in the top of the heads had no indication of milking. I also cleaned out the vacuum pump, lines and breather tank and changed the drive pulley. The vacuum pump is now spinning at 75% of engine instead of 50%. Now I am wondering if I am rolling into the burnout box too cold. And the initial hit of alcohol washes the cylinders and dumps into the pan. I would rather not give up on the alcohol now that I know the engine is tight. You guys say you are running 39 nozzles and 80 - 85 pill. I run at a normal density altitude of 5500 - 6000 feet. Shouldn't I be quite a bit leaner than you? |
describe your ignition system please? wondering if it is up to the task? trying to sort out a similar fuel system myself... :wink:
leakdown
David,
what should the barrel valve leak down be set at? |
Re: leakdown
Originally Posted by maxpower671
David,
If you do bail on this engine and go another route, there is better shops to choice from then Schmidt also :wink: Cold Compression test: 195 to 218 psi Leak down: one cylinder at 0% and one at 2%. All the others at 1%. Hot - 160 degrees Leak down: 3 cylinders at 1%, 4 cylinders at 2% and one at 8%. I changed to oil after the tests. It looked good. No milking. Warmed the engine and checked the valve lash. All were good. The oil in the top of the heads had no indication of milking. I also cleaned out the vacuum pump, lines and breather tank and changed the drive pulley. The vacuum pump is now spinning at 75% of engine instead of 50%. Now I am wondering if I am rolling into the burnout box too cold. And the initial hit of alcohol washes the cylinders and dumps into the pan. I would rather not give up on the alcohol now that I know the engine is tight. You guys say you are running 39 nozzles and 80 - 85 pill. I run at a normal density altitude of 5500 - 6000 feet. Shouldn't I be quite a bit leaner than you? If I run 39 nozzles with a 100 pill, that will be a far cry from the dyno that liked the 39 nozzles and 88 pill. The difference was that on the dyno, the engine temp was always above 150 F. |
You should always be above that on the track also, somethng I see often when dealing with carb or injection is this, people complain of there cars gaining 50-60 degrees from burnout box to the end of the track. It usually ends up they are very cold in the burnout box and they do not run the fan or water pump because they think it'll keep it cooler. To start the day out ALWAYS get it to 170-180 with the water pump on and then let it heat soak in the engine for awhile. Then go into the burnout box around 155-160 with the water pump on, you should be around 160-170 when stagging, make the run and gain 10 degrees, in the shutdown area-turn on the fan to run along with the water pump. When it gets back to the 170 range shut the fan and water pump off.
I talked to Ron's and they said that for each nozzle change (ie: 39 to 40) the pill should change 15 sizes (ie: 80 to 95). I never knew the correlation before. He was amazed that the best dyno runs were 41 nozzle and 88 pill and 39 nozzle and 82 pill, because they should have been 30 pill sizes apart. 39 / 82 correlated to 41 / 112. |
And the saga ends! Not with a spectacular solution either.
Ran the car last week with 39 nozzles and an 84 pill. I made sure I rolled into the water box at 180 degrees. No oil spray on the runs. Too little heat was the problem. I picked the vacuum pump RPM up to 75% instead of 50%. I think it was still building crankcase pressure because I had a small valve cover leak. I am going to leave the vac pump on and re-install my header evac system with check valves. Hopefully that cures the pressure buildup. Best run was 7.89 @ 169 mph. DA was 4500 feet. I wanted to thank all you guys, especially Hammer, for trying hard to help me sort this out. |
Ran the car last week with 39 nozzles and an 84 pill. I made sure I rolled into the water box at 180 degrees. No oil spray on the runs. Too little heat was the problem. I picked the vacuum pump RPM up to 75% instead of 50%. I think it was still building crankcase pressure because I had a small valve cover leak. I am going to leave the vac pump on and re-install my header evac system with check valves. Hopefully that cures the pressure buildup. Best run was 7.89 @ 169 mph. DA was 4500 feet. I wanted to thank all you guys, especially Hammer, for trying hard to help me sort this out. You OBVIOUSLY are Missing a INTERNAL Motor Issue,that Someone DONT wantto Deal with!!! SAD but TRUE! Later G :? |
Ran the car last week with 39 nozzles and an 84 pill. I made sure I rolled into the water box at 180 degrees. No oil spray on the runs. Too little heat was the problem. I picked the vacuum pump RPM up to 75% instead of 50%. I think it was still building crankcase pressure because I had a small valve cover leak. I am going to leave the vac pump on and re-install my header evac system with check valves. Hopefully that cures the pressure buildup. Best run was 7.89 @ 169 mph. DA was 4500 feet. I wanted to thank all you guys, especially Hammer, for trying hard to help me sort this out. BBchevy is correct thoguh, your likely on the edge and over driving the pump has helped. |
Re: ?
| All times are GMT -8. The time now is 11:06 PM. |
