-   -   Oil pressure (https://www.racingjunk.com/forums/showthread.php?t=21814)
skipjobe 09-17-2008 06:36 PM
storm
We got slammed thank the Lord we came out out healthy, I had 8 major trees fall and missed all the buildings. No power and my generator crapped out. Ran great for two days coil failed. back ordered to October. BBQing alot of meat before it spoiles mon by. I guess we will get back on the oil pressure next week or so.
zipper06 09-17-2008 09:12 PM
Re: storm
Dude, i've been wondering about you since your last post. i'm glad you and your family made it thru with all in tact and no major damage to your house. I know it may be weeks before all the power is restored, but health and saftey is formost and the other things will fall in line. For me IKE, totally missed me, it went northwest. I just got my yard back in order from Gustof today and that was 2 weeks ago, and donot want to see another in my lifetime.
skipjobe 09-25-2008 08:18 PM
oil pressure
We are finally straightened out from the storm, waiting for adjuster. Lots of clean up.
I called Melling today. They think the oil pump is cavitating at higher rpm, they recommended a pump with 10% higher volume part # 10552c with a anti cavitation oil screen that bolts on. I guess I will order one and give it a try.
skipjobe 10-06-2008 05:12 PM
oil pressure
Changed the oil pump on Sunday, I installed the pump that was in the motor before it was rebuilt that worked fine. Set the oil pick up to 3/8 from bottom of pan added a factory filter and still start loosing pressure at somewhere between 5500 and 6000.
I called Melling and they think the pump is cavitating, but this pump did not cavitate in this engine before up to 6800
The only thing I can think of is I had the builder add a torque plate to stiffen up the motor. Any ideas? I am stumped.
ocalasp76 10-12-2008 02:13 PM
FROM FLORI-DUH
On SBC motors there is an oil by-pass port located in the oil filter mount. We always plug this port so we have pressure at high RPM's. Also, we use the Fram HP-4 filter, it's more free flowing. Check out the port hole after removing the filter. Good luck.
---JIM----
skipjobe 10-13-2008 05:39 PM
Oil Pressure
I put on a moroso pan and removed the oil cooler now we have 80 psi @ 6000 rpm. Thanks
ocalasp76 10-13-2008 05:54 PM
WOW....What could be the blockage in the cooler or its lines?? :shock:
----JIM-----
outlaw256 10-13-2008 10:36 PM
is there any other way besides blockage that could cause oil cooler to be the culprit.i just traded for a car that has a cooler and the oil pressure is about 20 at idle and 40 going down the road. way to low for me but the car dont rattle, knock etc. im planning on freshening her up this winter but i sure would like to drive her for now.anyway i cant think of anything in a coo;er that could cause that but blockage.
suicidebomb 10-14-2008 08:22 AM
If there are any rubber lines going to or from the cooler, and those lines were expanding( ballooning), wouldn't that cause the pressure to drop at the gauge? I don't know, it might not be enough to show that much of a drop. Of course if they are hard lines, this would not apply at all. Just a thought.
skipjobe 10-17-2008 04:56 PM
Oil pressure
The oil cooler on this car has water going to the radiator rather than oil. So I suspect it was the pan.
