-   -   Internal balancer?? (https://www.racingjunk.com/forums/showthread.php?t=21008)
jrthone 06-14-2008 01:28 AM
I ended up buying a Fluidampr. Nothing against ATI.
cepx111 06-15-2008 05:59 AM
Originally Posted by jrthone
Cepx111 not all fluid damper are zero balance i have a fluidamper on my 468 and its an external balance one with a counter weight in it.
Ok but if your engine is balanced INTERNALLY like most racing engines you would need a NEUTRAL or ZERO balancer and flywheel ( no counter weights ) If your running a dampner and flywheel with a counter weights on a internally balanced engine your basically negating that costly balance job> Cp
jrthone 06-15-2008 04:36 PM
My fluid dampner and flexiplate are both nuetral.Thats what you have on internally balanced motors isnt it ?????
cepx111 06-16-2008 11:46 PM
Yes definetly, neutral for internall balanced and counterweighted for externally balanced.
>Cp
