-   -   roller lifters vs plain solid (https://www.racingjunk.com/forums/showthread.php?t=22237)
poncholvr 11-25-2008 11:07 PM
question, never used solid lifters-
are they solid,and pump no oil through them?,so u would need a oil rail to lube the rockers?or do they still pump a lil oil through them?
i understand the precision of them so they dont fade with heated oil,and less adjusting, just curious
jmarksdragster 11-26-2008 06:30 AM
Solids still pass oil, the big gain is the ability to go higher spring pressure and RPM. For the street they are a little noisy and do require periodic adjustment. You can get some pretty stout hydraulics if you need...
