how much fuel pressue at idle on 570 big block chevy, 871 bds blower, two doms 102
05-23-2014, 05:37 AM
on all corners, 16 percent over driven, 120 fuel, 10 feed 10 return
05-23-2014, 11:54 AM
Electric pump 6 psi should do it.
05-23-2014, 01:02 PM
thanks that's what its set at.
11-06-2014, 06:56 AM
6 to 10 lbs should be fine
10-05-2016, 02:07 PM
fuel pressure
[QUOTE6 at idle but what that is important is under a load at 7000rpm at 145 mph you need at least 4 lbs to 5
